Lights very dim on shore power
paulm235
Hi all, we are out with our keystone cougar 327res and are having an electrical problem. While on shore power the battery keeps draining and the lights in the coach are getting very dim. I checked the 2 fuses in the power converter and they look ok. The converter is a WFCO 55 amp converter if that worth the info. Not sure what to try next.
All the appliances are working as I would expect it's just the lights that seem to be the issue.
Any help would be greatly appreciated as we are currently using the rig.
Also keep in mind I'm not an electrician so please keep the solutions fairly simple :?
Thanks
2 dogs
06 Chevy Silverado LT3 2500HD CC SB D/A
MBRP Turbo Back, Airaid Intake, Predator Tuner
50gal Transfer Flow in bed aux fuel tank
Firestone Ride Rite Air bags
PullRite SuperGlide 14K hitch
2012 Keystone Cougar 327RES
9 REPLIES 9
Coach-man
Your lights work on 12 volts, from your battery! The battery is run down, you are not charging it. The converter everyone is talking about charges your batteries. It either has no power going to it, tripped breaker, or a fuse at the converter, or it has gone bad, which will require replacement !
lawnspecialties
1. Clean the terminals on your battery. I have seen the exact thing you're referring to on a friend's camper and all it was the battery connections needed cleaning.
2. Hook a battery charger to your camper's battery. If the lights get bright, then yes, the converter is probably going bad.
Puttin
OP, You should also be using some sort of surge protector as well. If not, this might have been a reason the converter failed. I agree the converter needs to go- it's a simple job but if you have the 55amp model it will run about $200.00 or so. Don't know about Best's pricing or Amazon, etc. If you're out camping you just may have to go to a store...call first with the model# and make sure they have it. Hope you're back on the mend soon!
tvman44
Sounds like the converter died. ๐Ÿ™‚
Papa Bob
Husky 16K hitch, Tekonsha P3,
dave17352
Your WFCO converter has failed.........replace it
Best Converter....ask Randy for options
x2
NOW 2017 Leprechaun 260ds
2005 Forrest River Cardinal 29rkle FW
1998 Lance 980 11'3" TC
2017 CHEVY 3500 SRW 6.0
B@W turnover ball @ companion Hitch
Honda eu3000 generator mounted on cargo rack
Crestliner 1850 Fish Ski boat mostly fishing now!
Old-Biscuit
Golden_HVAC
Check for a tripped GFI in the bathroom, or possibly in the basement storage. Try plugging in the battery charger to a extension cord plugged directly into the campground plug in. Or if at a friend's house, another receptacle than the RV is plugged into.
Good luck,
Fred.
Porsche or Country Coach!
Kangen.com Alkaline water
Escapees.com
time2roll
Probably need a new converter. Skip the WFCO and get a PD or IOTA.
Do the lights go out if you remove a battery cable?
For now run down and get a 10+ amp automatic battery charger. Put it direct on the battery. No need to disconnect anything. Pick up an extension cord if needed.
Appliances run fine down to at least 10.5 volts where the lights are real dim.
garyemunson
You'll need a meter to see if the converter is getting 120 volts AC in and, if so, if it's putting out 13-14 volts DC to the batteries. If the first is yes and the second no, time for new converter. The appliances work on the 120.
