Long bed vs. Regular Bed
trcgolf
I am switching from a 3/4 ton GMC 6.0L Crew cab standard bed, to a 1 ton GMC crew cab8ft bed diesel. My current fifth wheel hitch is a 15K rated slider unit. My max trailer weight is 11,200 lbs so the set up is plenty big enough.
Now that will have a 8 ft bed I shouldn't need the slider option for my set up.
Can I use what I have or do I need a need fifth wheel hitch.
2013 GMC 2500 HD
6.0 L Crew 4x4
Crossroads Zinger
15 REPLIES 15
sayoung
If you have no issues with current hitch keep it.Dont need a slider with a "REAL" truck bed:).Now on the other hand might be a good time to get a heavier rated non-slider hitch "just in case" you decide on a bigger 5er.
