โSep-21-2015 01:15 PM
โSep-29-2015 12:15 AM
Cummins12V98 wrote:valhalla360 wrote:
Volts x Amps = Watts (or close enough for our purposes).
If you have low volts, it's going to take more amps. If voltage is low, it tends to draw more amps and overheats. If it's a little, it will cause damage over weeks or months. If it's really bad, it could fry your air/con in seconds.
A transformer helps but as someone else pointed out, it's not a cure all by any stetch. In order to boost the voltage, it needs either more amps on the input side or fewer amps on the output side. Since the air/con needs a certain amount of amps, that means it needs to draw more amps from the campground system.
If the power is so bad that compressors aren't kicking over, it's probably too low for a transformer to help.
I guess you did not read this. Right from Hughes web site.
"The Autoformer DOES NOT take power from the park.
It does not affect the park or input voltage, or make electricity.
What it is doing is changing the voltage โ amperage relationship, lowering the amperage and raising the voltage. Since appliances run better on higher voltage, lower amperage, less overall power is used from the park, and better service is enjoyed from your RV
An Autoformer running at full output (50amps) will use 1 amp, but will cause appliances to cycle more often and run cooler. This will use less total power from the park."
โSep-22-2015 09:07 AM
โSep-22-2015 05:00 AM
โSep-21-2015 05:15 PM
โSep-21-2015 04:05 PM
โSep-21-2015 02:51 PM
2005 GulfStream Ultra Supreme, 1 Old grouch, 1 wonderful wife, and two silly poodles.
โSep-21-2015 02:04 PM
txsparky wrote:
yeah I need to check the voltage
Would low power affect the RV refrigerator performance?
would the power booster help if it were low?
โSep-21-2015 02:02 PM
โSep-21-2015 02:01 PM
txsparky wrote:If you are running refrigerator on AC definitely. It would be better to run it on propane.
โSep-21-2015 01:58 PM
โSep-21-2015 01:41 PM
โSep-21-2015 01:35 PM
2001 36' Kountry Star DP
โSep-21-2015 01:32 PM
โSep-21-2015 01:31 PM
