Mor/ryde system
lucy6194
After having a spring break on two different trips we are increasing spring weight and adding mor/ryde system. Has anyone added this system. Also adding wet bolt system.
8 REPLIES 8
Cummins12V98
"Is this something that can be retrofitted to a leaf sprung trailer?
Is that brake line also acting as a limiting strap? Sure looks tight. "
Yes they cut everything off right up to the frame and attach the IS system.
Good eye on the brake line! I had Rolling Retreats adjust it when they took delivery.
When I have my 2" riser added at MorRyde later this month they will be completely re routing the brake lines. From what they told me it will be a big improvement over DRV's job.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
ixsna
that brake line is way to tight even when the weight is on it id want more clearance then that its already kinked right over on the top.... with this being said mor ryde IS is tough to beat its the only way to go unless you wanna save money and just switch it to dexter torflex axles
Bobandshawn
Cummins12V98 wrote:
TheAmRheins wrote:
Take Cummins 12v98's advice everyone that goes that route can't believe the difference
There is nothing out there that compares IMHO. Our MS on the assembly line.
Cummins12V98
TheAmRheins
Ken & Kathy
Ruben(the cat)& Tiadora (nother cat)
2003 Chev 3500 D/A Dually
2009 Landmark Augusta
Cummins12V98
Do your self a favor. Install the MorRyde IS you won't regret it! With disk brakes.
bkick
I did this several years ago and it really made a difference, I also changes the springs, adding another leaf that increased the height by 2 inches. Would not believe the change in the ride, less bounce and a lot less sway. It did require that I raise the hitch one bold hole to level the trailer again when hooked up. Good Luck.
Bkick
RustyJC
Are you referring to the full MorRyde independent suspension system or the MorRyde equalizers for a leaf spring solid axle suspension system?
Rusty
2014.5 DRV Mobile Suites 38RSSA #6972
2016 Ram 3500 Dually Longhorn Crew Cab Long Bed, 4x4, 385/900 Cummins, Aisin AS69RC, 4.10, 39K+ GCWR, 30K+ trailer tow rating, 14K GVWR
B&W RVK3600
