โOct-30-2013 02:13 PM
โNov-02-2013 04:17 PM
โNov-02-2013 01:07 PM
โNov-02-2013 10:44 AM
โNov-01-2013 05:54 PM
โNov-01-2013 04:33 PM
โNov-01-2013 12:38 PM
โNov-01-2013 12:14 PM
full_mosey wrote:larry barnhart wrote:
If Ed had 2 6 volt batteries and one went bad he would be in big trouble??
chevman
Easy. If half of your 12V bank of 2 x 6V in series goes bad you have no 12V. Possible, but not probable. Worst case you buy two new 6Vs.
If this loss of power creates a medical emergency then consider 2 x 12V in parallel where you can limp along on only one battery.
HTH;
John
โNov-01-2013 09:26 AM
chevman
โNov-01-2013 09:00 AM
Ok I will ask again as I have done several times without a good answer. If Ed had 2 6 volt batteries and one went bad he would be in big trouble?? I feel he would but it seems nobody on this forum agreed the other times I asked this simple question.
chevman
โNov-01-2013 07:49 AM
โOct-31-2013 10:11 PM
โOct-31-2013 04:45 PM
mr. ed wrote:If you don't boondock one will be just fine.
Thanks for all the replies and suggestions.
Reply to John: I check battery water level frequently and the batteries were just topped off before my trip from Arkansas to Florida.
Reply to Dino Bill: I have given some thought to obtaining a different type of battery in place of the lead/acid type due to vibration concerns. I'll probably go that route.
Another quick question: Since I don't boondock will I be OK with just one battery (no doubt the type suggested by Dino Bill)? I don't see any need for two if one can do the job, but I'd like to get others' input on this.
โOct-31-2013 04:23 PM
โOct-30-2013 06:49 PM
