No Direct TV Receptions
franxpace
Just got our new Alpine 3600RS. Set up my Direct TV Dish and for some reason, the signal does not enter the rig on either of the two TVs. Is there a switch or connection with the unit that I need to focus on?
23 REPLIES 23
FlatBroke
Three fith wheels only the one we own now work on satellite. There were ends on them our the cable just had to be replaced, staple through them or ran wrong. Manufactures need to go to TV school. Most folks don't even check them when purchasing. I didn't on the first one. I did on the second one but they had to take pictures and send them in before they could fix it. Fixed it myself in five minutes because I could see they didn't know sqaut about them.
Hitch Hiker
"08" 29.5 FKTG LS
Me_Again
The sat prep wires probably go to the roof, not the input on the side. Chris
franxpace
The dish checks out totally. Good reception and all. I suspect it is the wiring since there are two connections โ€œsatellite preppedโ€. Two orange wires go from there two black wires spelt from the orange. At the tv connections, I have an antenna connection. and two other connections, ( I suppose for cable). One is grey and one is orange. The bedroom has a grey connection as the satellite connection. Probably have to re-wire as some of you have suggested. Thanks for all the inout, everyone.
shadoow
franxpace wrote:
... the signal does not enter the rig on either of the two TVs.
are you able to get good sat signal strength but no picture or are you having difficulty getting sat signal strength?? What sat dish are you using (18" round, slimline w/SWM, etc.)
RoyB
On my older TV setup I had to run two RG cables into the trailer from my two port SAT DISH to two SAT RCVRS one in the living room and the second one in the bedroom. Have no idea how the newer trailers are setup to do this...
Then I ran VIDEO CABLES from the SAT RCVRs to the VIDEO INPUT on the TV sets.
This was how I got mine to work and also each TV can watch different channels.
The problem you may be having is the SAT DISH control voltage has to get from the SAT RCVR to the dish. Those connections you are using must be prohibiting that from happening.
Roy Ken
Roy - Carolyn
K9PHT (Since 1957) 146.52M
2005 Flagstaff 8528RESS
tvman44
Does your rig have satellite prep? If you do check to make sure it is wired correctly. Not all units come with satellite prep. ๐Ÿ™‚
Papa Bob
Husky 16K hitch, Tekonsha P3,
Duck
I presume that you switched your TV to sat from cable reception with your remote setup program.
Don
08-FORD F350 PSD
13 Bighorn 3055RL {For Sale}
jconnally
You basically have to have a direct connection from the satellite to the receiver with no splitters or amps in line. Since it's a new unit it may be wired for satellite but should be marked. I would run a cable straight through the door to the receiver and set up the dish. Once I know it works I would then attempt to use the trailer wiring because even if prewired for satellite they could be crossed.
2008 Chevy 3500 SRW Duramax/Allison
2011 Sierra 345RET 38'10"
(2) Honda EU2000
Ramblin_Recks
I have 3 coax inputs on the outside of my rig, and it was wired incorrectly. The one mark "SAT" was connected to "Cable". So I reversed them from behind the panel.
George and Ann
2012 Dodge 3500, SLT Big Horn,CC,DRW,Cummins HO, EB ,4x4,3:73, Retrax Pro, Q20
2014 Cedar Creek, 36CKTS, 640W Solar, MPPT60, Magnum 2000
Retired Army, but still working....until 2016
