Yours may be similar to mine. The notched front cap design means the front crossmember across the front of the pin box brackets is also notched and therefore attaches to the frame members further back, very close to the back crossmember. This setup has more flex than older frame designs. The front cap does not attach to the frame, it only attaches to the walls and roof. So, what you experienced is consistent with excessive flex.
The front closet floor is attached directly to the steel frame and will flex with the frame. If you set a target on the closet floor and set a laser level on the bedroom floor as far back as possible (directly above the landing gear is good), then you can measure the amount of flex between hooked and unhooked.
This flex occurs without broken welds. Mine was substantial, didn't want to take chances and had it fixed under warranty.
Larry Day
Texas Baptist Men-Retiree Builders since '01
'13 Silverado 3500HD LT 2wd CCSB SRW, custom RKI bed
'19 Starcraft Telluride 292RLS
Rig Photos
