โDec-22-2015 04:11 PM
โDec-23-2015 03:09 PM
โDec-23-2015 02:28 PM
โDec-23-2015 01:53 PM
Coach-man wrote:
had that same hitch on my last truck. Those holes are not there to adjust for the spacing of the rails. They are there to allow you to move the entire hitch forward or back from the centerline of the axle. The rails are designed to be spaced the same distance apart for every hitch. That way you can interchange hitches using the same rails. If you purchase model specific brackets for your install they will set the rails at a specific spacing, but there is a slight amount of tolerance that will aloow them to move slightly. You will need the hitch to get the exact spacing. I hope you are shopping online for that Super Glide. I found mine online for 1/2 of what a local dealer wanted.
B.O.
X2, BUT industry standard, means "industry standard" You do not need the hitch, if you install the rails per industry standard dimensions! That way any industry standard hitch should work. Read my post, no hitch, installed per instructions for "industry standard" hitches, and guess what it worked!!!
โDec-23-2015 12:35 PM
โDec-23-2015 10:53 AM
Coach-man wrote:
OK, Kevin-0, from the rear of the bed it is26 ยฝ", and the rails are 22" between them. Again I did not have a hitch, I purchased a Pullright Superglide later when I purchased the fifth wheel. I cut the bed liner, so the rails sat flat on the metal bed. I used the above measurements to locate the rails, then drilled down thru the bed, and used the bolts to locate the frame brackets. Not a particularly hard installation, but take your time, measure twice, cut once! You are not playing horse shoes, so almost does not cut it! When finished, the super glide sits perfectly, with the pin just in front of the rear axel.
โDec-23-2015 10:28 AM
Kevin O. wrote:i had that same hitch on my last truck. Those holes are not there to adjust for the spacing of the rails. They are there to allow you to move the entire hitch forward or back from the centerline of the axle. The rails are designed to be spaced the same distance apart for every hitch. That way you can interchange hitches using the same rails. If you purchase model specific brackets for your install they will set the rails at a specific spacing, but there is a slight amount of tolerance that will aloow them to move slightly. You will need the hitch to get the exact spacing. I hope you are shopping online for that Super Glide. I found mine online for 1/2 of what a local dealer wanted.WTP-GC wrote:This is the hitch I want to purchase.
Having installed the bed rails in my previous TV, I would not want to do it without having the hitch.
It comes with adjustable brackets so it can be made to fit on any set of standard bed rails. Unfortunately for me this hitch will not help me find the placement for the front rail. I guess I'll just spend the extra $$ and let a shop install the rails..
โDec-23-2015 10:21 AM
โDec-23-2015 09:57 AM
โDec-23-2015 09:36 AM
Coach-man wrote:Thank you for taking the time to do that for me! I will give it a try myself..
โDec-23-2015 07:45 AM
Coach-man wrote:
OK, I guess I did it wrong! First when I installed my rails I had no hitch. Second, since I had a drop in bed liner in my TV, I measured from the rear of the bed to the back of the rear rail to locate the rails. Can not remember for sure, but I thought the distance between the rails was mentioned in the instructions?? I have a 2006 RAM 2500 short bed, and I will go and measure and post my measurements, I hope they are helpful, but I would try and get exact measurement for your particular TV.
โDec-23-2015 07:33 AM
bpounds wrote:
The frame kit you selected has fixed centers for the rails, unlike the universal style kit. So the rough center distance for the rails is determined for you. You need the hitch base to fine tune the fit.
Here is the install PDF which shows how the frame adapter ears will determine the rail centers.
โDec-23-2015 07:21 AM
Kevin O. wrote:WTP-GC wrote:This is the hitch I want to purchase.
โDec-23-2015 07:16 AM
โDec-23-2015 06:49 AM
