โSep-23-2018 08:28 AM
โSep-30-2018 06:27 PM
dieseltruckdriver wrote:
Back on topic, I had a sliding bar hitch at first, then switched to the B&W because I didn't want the rails in the bed when I wanted to use my pickup as a pickup.
Do not get a sliding bar hitch. They wear and then the trailer will "slam" fore and aft as you are driving. If you get a hitch with wrap around jaws, this doesn't happen. The sliding bar will be secure, but they aren't smooth.
I drove semis for 17 years, and have used a few different kinds of hitches. The Hollands were my favorite.
Since you are new, immediately after you hook up, go to the back of your pickup and look at your hitch and pin, to verify they are mated correctly. A pull test is optional, but always visually verify that things are correct before you pull.
Do this every time, without fail. I check, then do my walkaround to make sure everything is ready to travel, then check it again.
โSep-30-2018 07:39 AM
โSep-30-2018 07:28 AM
goducks10 wrote:Cummins12V98 wrote:goducks10 wrote:
I back into my B&W jaws and the handle slams back. Grab the 5er safety brake wire and slip the lock pin thru the hole in the handle. Walk to the rear, take a look at the jaws and then plug the 7 wire cord into the truck. No need for a pull test in 5 seasons. It just doesn't get any easier IMO unless you're using an Andersen as far as not needing a pull test.
OMG!!! Are you actually saying itโs not required to do a pull test with your hitch???
You are actually using your EYES as a verification TEST???
Ummm yeah. ๐
โSep-30-2018 06:58 AM
โSep-30-2018 06:17 AM
Cummins12V98 wrote:
Using a B&W you know there is no way to drop the hitch if you simply make sure the hitch and pin box plates are touching each other, the hitch handle is closed and pinned/locked and a quick look to see that the 1" machined jaws are around the kingpin.
Do the above and there is ZERO reason to do a pull test.
โSep-29-2018 08:01 PM
โSep-29-2018 07:18 PM
larry barnhart wrote:memtb wrote:larry barnhart wrote:
Ron how is yours different than our reese. Seems it does the same thing as you describe. I do a pull test because it is easy. Hit the trailer brake and try to pull ahead. Not that tough to do.
chevman PS will be going south again so of course the pull test will be done.
And.....you verify that the trailer brakes are working! ??
yes and will be the same every time we hook up. No reason to stop.
chevman
โSep-29-2018 07:14 PM
โSep-29-2018 01:06 PM
โSep-29-2018 12:37 PM
โSep-29-2018 12:27 PM
โSep-29-2018 10:17 AM
โSep-29-2018 08:45 AM
โSep-29-2018 08:36 AM
wvcampers wrote:
I went from Reese to Andersen rail version. I recently traded trucks and the new one came with the B&W companion mounted with factory puck system. I have towed with it 2 times. I really like the Andersen due to the fact that there is no way to drop the trailer on the truck like you can with a traditional hitch. For beginners the Andersen is a much easier hitch to safely use and very easy to remove from the truck.
