Propane regulator making noise
12th_Man_Fan
Recently I have noticed when I am using the furnace in the RV I am hearing a fairly loud noise comin from the propane regulator. For lack of a better description it sound like a rattle.
My Rv is a 2015. Is it time to replace the regulator already or is this a normal thing.
The other night I could hear it in the bedroom.
2014 GMC Duramax 4X4 DRW Crew
2015 DRV Tradition
15 REPLIES 15
time2roll
I believe you will be much happier with the operation of the Cavagna.
At least it is quiet, right? ๐Ÿ˜‰
12th_Man_Fan
I replace mine with the cavagna 924. I love it. My old one was mounted on the side of the bin and I could not tell when the red flag came up without removing the tank. I could not move it due to the size of the bottle and compartment. The cavagna solved that problem.
Thanks for the replies.
2015 DRV Tradition
reluyog
Gasman6674, No problem, and I agree with the getting older part! It seems I used to get more done everyday.
Damian
1983 KW W900, 3406B Cat, RTO14615, 355's
1995 Carriage by Carriage triple axle 22K
GASMAN6674
My apologies I needed to look at the picture closer. It sucks getting old
Jim & Debbie England
Do you have Gas? Propane Exceptional Energy
2015 F350 CCLB 6.2L/4:30 Vermilion Red
2020 Cougar 364BHLGone but not forgotten 2012 Ridgeline 34RLT fifth wheel/2012 V27FK V-Cross TT
reluyog
Gasman6674, The tanks pictured DO have OPD valves, I'm using the internal threads for connection.
Damian
GASMAN6674
The RegO 7525 series is a twin stage regulator. the change over head is the first stage (tank to 10psi) and the second regulator is the low pressure (10 psi to 11"wc) The unit carries a 10 year warranty. PS be aware the tanks shown in the picture are no longer "legal" all DOT bottle up to 40# require a OPD valve and all OPD valve have both internal POL and external QCC connections So you can continue to use POL pigtails thou I would recommend excess flow style connections. Your Unit- Your Loss
NRALIFR
reluyog wrote:
The way I figure it, if there's a fire, the rubber hoses will become compromised and the opd overflow valve will be applied.
No, it wonโ€™t. Thatโ€™s what the excess flow check valve does that is part of the new style pigtails with the green Acme nut. It prevents unrestricted flow of LP in case the hose is broken. The OPD only prevents overfilling the cylinder. The thermal bushing in the Acme nut, when it melts in a fire, allows the pigtail fitting to back out of the valve on the cylinder (itโ€™s spring loaded) closing off the flow.
reluyog wrote:
I believe it's just a single stage regulator. The key for me is not to restrict the flow of propane, as much as possible anyway.
The reason I asked is because it was my understanding that a dual stage regulator was required on RVโ€™s. Yours may very well be. Like I said, Iโ€™m not familiar with that brand. But, whatโ€™s OK to do on stationary LP systems (like on a mobile home) isnโ€™t always OK for an RV system. If the green Acme nut (200,000 btu) was not allowing enough LP to flow for you, you could switch to pigtails with a red Acme nut, which can flow up to 400,000 btu.
2001 Lance 1121 on a 2016 F450 โ€˜Scuse me while I whinge.
And for all you Scooby-Doo and Yosemite Sam typesโ€ฆโ€ฆโ€ฆ..Letโ€™s Go Brandon!!!
reluyog
The way I figure it, if there's a fire, the rubber hoses will become compromised and the opd overflow valve will be applied. I believe it's just a single stage regulator. The key for me is not to restrict the flow of propane, as much as possible anyway.
Damian
NRALIFR
The OPD in the cylinder and the excess flow check valve in the pigtails that have the Acme nut are not the same thing. They protect you from two different hazards. The Acme nut also includes a thermal bushing that melts in the presence of fire, and will disconnect the pigtails from the valves.
Iโ€™m not familiar with that brand of regulator. Is it two stage?
reluyog
Hopefully this is a pic that will zoom. The hose connections are just old fashioned style full flow connectors. I rely on the OPD valve overflow protection instead of having another overflow protection valve in the new style hoses.
Click For Full-Size Image.
Damian
time2roll
I believe the ACME nut is designed to melt in a fire to disengage the pigtail and close the valve to stop further propane release.
wopachop
Wow thats nice. Is that the 7525? Im looking them up online. On my laptop im clicking your picture but cant seem to zoom.
Never seen anyone run the reverse thread like you. Is the idea similar metal will be better than the plastic Acme? Or is the inside diameter of that hose larger? Or both?
edit: oh wait its the inside diameter of the connectors that are larger? Recently got some high flow air compressor fittings. Something new and fun to play with.
reluyog
I replaced mine with a commercial grade Rego unit and full flow fittings. Extremely reliable.
Good luck.
Damian
time2roll
I would take the Cavagna over that Marshall any day. Much easier to read and no guesswork.
