Propane tanks 10 years old, what is best choice ???
ilvtravln
Hi, My propane tanks on 5er are 10 years old, do I leave them as is, replace them, recertify them or what, not sure, not having any problems with them, where we go camping often they never check the date on them as they refill them, not even a scratch on the paint any input would be appreciated. Thanks
Art
31 REPLIES 31
time2roll
If you can get an easy and cheep re-certification that is fine. I just bought new 30# cylinders from Costco.com to be done with it.
Old-Biscuit
Recertification....
Visual Inspection good for 5 yrs then repeat again and again and again
1. Damage to the cylinderโ€™s exterior including dents; bulges; cuts; or cracks on the cylinderโ€™s surface,
or to welds; and any evidence of physical abuse; fire; or heat damage.
2. Detrimental rust, corrosion, or pitting on the cylinder, particularly on the bottom.
3. Absence of/damage to a cylinder footring, cylinder neckring (collar), or valve cover.
4. A leaking or defective valve or leaking or defective pressure relief device.
Cheaper then buying NEW Cylinders
Depending on State/Location recert could be $7 up to $35 (rip off)
Check your local area for a BULK Propane Vendor (Suburban, Ferrellgas, Amerigas etc) Tractor Supply may do it also
Recert requirement WAS 12 yrs after date of MFG....legislation was passed/post-poned to change that to 10 yrs after MFG date
Many places use the 10 yr requirement
