My 2010 F150 Truck tow package came with a camera in the rear FORD tailgate emblem. It is perfect for backing up to the RV Trailer and hookup... It also has foot markers on it as well. I can see the BALL go right under coupler.
This only however comes on when in REVERSE... It is worthless at night and also when it rainsโฆ Two or three rain drops completely covers the small lens I guess...
If I was going to add camera to a RV Trailer I would want two on the rear sides... If I had a tall trailer I would also want one in the top near the roof pointing down at a sharp angle...
Same goes for lights in the back... DOT frowns on you adding lights to the bumpers and lower back areas... They have rules for BACK UP LIGHTs.. One biggie is it has to come on only when you switch to reverse. Cannot be a stand alone toggle switch some where...
You can mount a light on the bottom rear sides of the trailer with external switches here in Virginia at any rate. I went and asked.. This is good to aid in backing... You can't see directly behind your trailer anyway so seeing both side behind the trailer works out just as good...
I know of several friends here in Virginia that had to remove their lights and items when it comes Inspection time... I guess the best thing to do here is get it DOT blessed before you dump money into it...
Roy Ken
Roy - Carolyn
K9PHT (Since 1957) 146.52M
2005 Flagstaff 8528RESS
