Question about my Hydraulic Resevoir
abc40kids
Just got this 2015 Mountaineer and noticed something last night while starting to put things in the camper. So all slides are in but 6 point level is down..... The Hydraulic resevoir has a fill line near the top but reservoir only has a few inches of fluid in it.
If I retracted the six point will it fill up that much? I probably should have done that before posting but just thought about the leveling being down.
Jeff,Julie,Amber,Brandon,and Casey and Winston ( our 5 year old Golden ) and Bruno the Pug. We now have an English Cream, white Golden Retriever as well.
2015 Keystone Montana Mountaineer 356TBF
2005 Chevy duramax dually
3 REPLIES 3
eHoefler
The fluid level should be at the full line only when all Hydraulic operated items are retracted. If any of them are extended and you fill it to the full mark, expect a big mess when you retract everything!
2021 Ram Limited, 3500, Crew Cab, 1075FTPD of Torque!, Max Tow, Long bed, 4 x 4, Dually,
2006 40' Landmark Mt. Rushmore
waltbennett
Don't have a Level Up system, so I can't answer you on that. Have you tried the Montana Owner's Club forum? http://montanaadministrator.forumco.com/
'06 F350 TD, Softopper, airbags, AeroShield, coolant filter
'10 3665RE Hickory edition, wetbolts, Firestone LTs, Trimetric Battery Monitor, 4x100w panels & Morningstar TS-45, still tweeking.
WeBeFulltimers
I would retract the 4 rear levelers and then fill the reservoir to the line. "A few inches" is not very descriptive. Is it 3 or is it 9. Could make a big difference in this case.
2012 Ford F-350 PSD SRW ** CURT Q24 ** 2018.5 MONTANA 3791RD
