Ram Factory 5th Wheel prep, Which Hitch?
timesquare
I know this has been covered before, but I was hoping now that this prep has been out for awhile and more companies have introduced Hitches for this setup, I could get real world experience.
Pulled the trigger on a 3500 Longbed, to replace the one totalled by a drunk driver in front of my house.
Didn't think twice about the Factory prep, until it was time to install my hitch. Pullrite Super5 20.5. Thought all I needed was the new base that Pullrite just released.
One call to confirm,,, Wrong,,, Hitch is useless.
After some research, options are
B&W Companion Hitch with fits into the Pucks(Serious backorder) What's up with having to torque bolts on a regular basis?
Curt Q20 with the new legs that work with the Dodge factory prep
Pullrite ISR Hitch on their New Brackets (seems like the base rails would add more areas for movement)
These are the three I have narrowed it down to,but open to others
Looking for opinions and experience of the different brands since they price out close to each other.
I like the pullrite locking jaw system, seems like its fool proof, had a Superglide, before the current hitch never a problem, except for unhitching on uneven ground. But the two jaw setups are very common I just don't have any experience with them
Wasn't expecting to shell out this much on a hitch, but it is what it is.
So any advice would be appreciated
21 REPLIES 21
sh4717
I have been using the Andersen Hitch in my Dodge. I came from a Superglide also and the Andersen is the best setup I've ever had. Just another option for you. Good luck.
Scott
2019 Northwood Nash 24M
2018 Ram Ecodiesel
glazier
The bolts are on the Companion U Bolts, and the draw bolt. My slider only has a draw bolt to torque to 80lbs.
2017 Grand Design Momentum 328M
2015 Chevy 2500HD LTZ Duramax CC/SB/4X4
B&W Companion Slider
timesquare
I will have to check out the picture frame adapter. I just assumed my hitch wouldn't work on it since its not the industry standard or ISR as Pullrite has told me. Certainly worth a good look! Thanks for the Info.
(There were posts about people having to torque some bolts on the B&W hitch, not sure which bolts they were talking about(.
BusaGuy
Any pics of this setup?
2012 Dodge Ram 3500 DWR Cummins Powered
2014 Wild Wood Heritage Elite
DW, DD's, DS, and our 2 little dogs!!
NC_Hauler
glazier wrote:
What bolts would you have to torque on a puck system?
That was my point..There shouldn't be any bolt's....T-bolts lock into place, once adjusted correctly and one should be "good to go".
Jim & Kathy, (Boxers, Buddy & Sheba)
2016 Ram 3500 DRW Longhorn 4X4/CC/LB/Aisin/4.10/rear air assist ...Pearl White.
2016 DRV MS 36RSSB3/ W&D/ slide toppers/ DTV satellite/ 5.5K Onan propane gen.
B&W RVK3600 Hitch
Fulltiming in WV & TX
USAF 71-75 Viet Nam Vet
NC_Hauler
I have the 5er/GN prep package and purchased the picture frame adapter and attached my existing Reese 20K Signature hitch to it...No problems.
I don't know about your existing hitch, but it should fit, I think, the picture frame adapter. Reese makes one for a little over $300 , free shipping. I do like the new hitches that they're coming out with that will fit in the puck lock downs in the truck...your call..."IF" your existing hitch WON'T work with a picture frame adapter, than it sounds like one of the three you mentioned, though more expensive would work best for you.
I don't know about "torquing down" the T-locks....I had to adjust my picture frame adapter a little, then it locked into the prep package and I haven't touched it since.
Hope this helped...
Jim
B&W RVK3600 Hitch
glazier
