Rear door edge wear
motodirthead
I have a 2010 Fuzion 302. Recently I noticed that the edges of the rear door aluminum frame is wearing significantly under the door latches. The door probably rocks back and forth under the latches when traveling down the road. Anybody have a similar experience and repair suggestion?
I was thinking about having a sheet metal shop cut out some thin stainless steel strips to rivet to the door frame under the door latches.
2008 Chevy 2500 CC, DMax
2010 Keystone Fuzion 302
'14 KTM 200 XCW
'13 KTM 250 XC
'08 KTM 450 XCRW
3 REPLIES 3
motodirthead
Rear ramp door
'14 KTM 200 XCW
'13 KTM 250 XC
'08 KTM 450 XCRW
Bedlam
Moderator
Moderator
You may want look at the structure supporting the door frame. If you are getting excessive movement, the framing may be floating/detached allowing for flex.
64thunderbolt
entry door or ramp door?
Glen
04 Tail gator XT 34' 5th wheel garage model
200w solar 2 GC2's 800w inv
Truma tankless WH
99 F350 CC DRW 7.3 ais intake, adrenaline hpop, JW valve body,
cooling mist water inj, DP tunes, 4" exh sys
trucool trans cooler added
2011 RZR 900xp
