Rear Ramp Door Hinge Pin
holidayrvguy
We Have a 2005 Fleetwood gearbox with the rear ramp door.The ramp wood has gotten really soft and we are wanting to repair.The problem is It looks like theres pins that hold the rear door on at the bottom.Can anyone tell us how to remove the pins,is it just one pin that go all way to the other side or 2 pins?Any removal Instruction would be great.
Thanks
7 REPLIES 7
holidayrvguy
Thanks,I seen that post,but really not that much info.What I need to know is does the pin go all the way through or is is it 2 single pins?
And how do you remove.Thanks again in advance.
Oh! The springs are attached on the inside and just assist the door.
big_buford
Found This
04.5 GMC 2500HD D/A
06 38 CKS Dune Chaser
Chenowth 4-seat 3.5 honda
15 maverick xds
Beautiful wife that's much nicer than me:B
big_buford
Have a friend who's pin cracked in half, i'll find how he got it repaired in the am.
04.5 GMC 2500HD D/A
15 maverick xds
Y-Guy
Moderator
Moderator
Wow that is a different setup. Hopefully somebody has some advice, I'd be cautious until you know where the springs are at in that type of setup.
Two Wire Fox Terriers; Sarge & Sully
2007 Winnebago Sightseer 35J
2020 Jeep Gladiator Rubicon
holidayrvguy
Mod Edit: Created photo links.
holidayrvguy
Okay will try with photo bucket
Y-Guy
Moderator
Moderator
If you can post a photo that would be helpful, not all ramp doors are the same.
