Recently bought a sandpiper 365saqb... Having problems
cjwells05
We recently purchased a used 2015 sandpiper 365saqb. We took it on
a quick weekend trip without any problems before we headed out on a 3 week cross country trip. We are 2 weeks in and have had the fuse that works the slides blow twice and the fuse that works the auto level has blown once. Any idea why? All help is appreciated.
4 REPLIES 4
Jimf1234
Is it a fuse or the breaker for the hydraulic pump? Does it fix it itself after a minute? This was also happening on my 365 so I added another breaker to split the load and haven't had any other issues. Going from memory I think it was supposed to have a 50amp breaker but only came with a 30amp
2013 Sandpiper 365 SAQ
2016 Dodge 3500 900ftlbs Limited
vampirefish
My 371REBH Sandpiper's slide out fuse blew and they had to replace the control panel on it (something like that). Have had nothing but problems with this unit ๐Ÿ˜ž
2004 Jamboree GT 31W
filrupmark
Since its happening in two separate systems with one common part. I would check the water in your batteries first. Low voltage causes high amperage which in turn blows fuses. You also should do some lubrication maintenance to the slides and leveling system.
2004 Ford F250 Super Duty 6.0 Diesel, Bilstein 4600 Shocks, 16K B&W Patriot, Michelin M&S
2014 Augusta Flex AF34RS Trailair Tri Glide pinbox,
JT Strong Arms , Bridgestone R250'S, KYB Monotube Gas shocks
Finally a smooth ride !!!
garyp4951
I would post this in the Tech Issues section.
