Sanibel 3800 comparison
On_the_road_Jou
Looking for a bit of information and help in regards to the comparison of the 3800 Sanabel to other 5th wheels of it’s caliber and floor plan. By that I am meaning with its aggressive winter package. Looking for possibility of other options to compare it with on the market as to what can match it or out perform without breaking the bank?
17 REPLIES 17
Lantley
I was going to suggest Excel as well but now that they are defunct I figured it was no point bring them up.
Buying used orphaned model presents another set of challenges for a newbie
Splashers3
x2 - with a high end used model.....Excel was an excellent high end 5ver, although Petersen Industries is no longer are around.
It's kind of depressing when you can't find the quality that you'd expect when paying big $$.
2017 GMC 3500 Sierra Denali, C/C, D/A, DRW, w/40gal Aux tank, 18K B&W Patriot.
2019 Cedar Creek Hathaway, 34RL2 - w/Bells & Whistles and disc brakes
Traded 2009 Cedar Creek Silverback, GII, 32 WRL
TXiceman
If $65k is your top, look at nice used higher end units over new entry level. You will get a lot better bang for your buck.
Ken
Amateur Radio Operator.
2023 Cougar 22MLS, toted with a 2022, F150, 3.5L EcoBoost, Crewcab, Max Tow, FORMER Full Time RVer. Travel with a standard schnauzer and a Timneh African Gray parrot
Lantley
On the road Journey wrote:
So if I’m hearing you correctly and understanding what you’re saying I’m not gonna be able to pick up any sort of decent quality 5th wheel for what I’m looking for without spending hundreds of thousands of dollars? My price range is top dollar right now $65,000.
Sort of correct RV's are not very well insulated despite are the marketing Jargon.
RV's are used in moderate temps. 95% of of RV's are not built to withstand Extreme cold.
Northwood Manufacturing- Arctic Fox are known for there well insulated trailers however their floorplans are somewhat limited vs. other makes They cater to a niche market and build quality units. If withstanding extreme cold is your priority. Arctic Fox is your best bet.
On_the_road_Jou
Splashers3
Not sure what you want to spend....if DRV $$ didn't bother you, look into New Horizons.....you can customize it.
Good Luck.
On_the_road_Jou
Looking for something along the lines of 42’ though.
On_the_road_Jou
Looking for something about 42’ though.
TXiceman
Check into Arctic Fox.
Ken
On_the_road_Jou
What suggestions then would you be able to give to me in regards to a good solid 4 season RV? As far as models brands and a starting point for me to kind of look into?
Splashers3
The Prime Time (Sanibel) web page doesn't define what the extreme thermal package consists of....
From what was available, the CC appears to have higher R values and BO Plenty's 36CKTS may have thermal window panes.
I didn't compare the DRV specs, maybe BO Plenty did.
Lastly, not everybody can afford a DRV...or want to...for all they cost, they have their share of problems too.
On_the_road_Jou
So what is with your 2016 Cedar Creek 36CKTS???
On_the_road_Jou
So what is with your Cedar Creek 36CKTS Then???
B_O__Plenty
What aggressive winter package are you talking about? You need to look at trailers with thermal pane windows, walls that are thicker than 1 1/2 or 2 inches, ceilings and floors with real insulation not that silly aluminum foil bubble wrap stufF with all the false R value claims. Then you will be looking at a REAL winter package..DRV would be a good place to start.
B.O.
Former Ram/Cummins owner
2015 Silverado 3500 D/A DRW
Yup I'm a fanboy!
