Jun-16-2020 01:50 PM
Jun-16-2020 07:13 PM
Jun-16-2020 05:26 PM
Jun-16-2020 04:45 PM
Lynnmor wrote:Most of the suspensions I've seen, including the one I replaced use a through bolt, and yes it is knurled. The bolt has no shoulder and the nut, usually a Nylok, is tightened down snug enough to allow the spring to move within the shackles. And also when slightly worn, allows the shackle to move on the bolt. This causes wear on the bolt, and on the shackle, so you can end up with elongated bolt holes and worn shackles. When the shackles are bolted solid like the wet bolt kit, the only movement is the spring rotating on the brass bushing. The shackles cannot wear out because they don't move, and therefore don't wear.fj12ryder wrote:jdc1 wrote:Not really the full story. They do away with this whole crappy system of just snugging down the nuts so the shackles/through bolts can rotate with the movement of the suspension. The wet bolts use shoulder bolts that tighten down to the shackles and there is no movement except the through bolts in the brass bushing. This is how the suspension should be set up from the factory.
A whole wet bolt kit is $100 on Amazon. THey're just greasable bolts, sleeves, ect.
I don't follow that explanation, the original bolts with straight knurling to prevent rotation. In my mind it is still the same crappy system with bronze bushings replacing the plastic ones and a halfass way of greasing.
Jun-16-2020 04:12 PM
Jun-16-2020 02:48 PM
Jun-16-2020 02:35 PM
Jun-16-2020 02:33 PM
fj12ryder wrote:I should do that. It sounds like the tricky part is getting the weight off by jacking in the right places.
Replace those half-ass shackle assemblies with wet bolt kits.
Jun-16-2020 02:30 PM
Jun-16-2020 02:28 PM
Jun-16-2020 02:20 PM
Jun-16-2020 02:09 PM
