Slide Out
bmcdonald
We have a 2008 Cardinal with 3 slides. The bedroom, kitchen slide goes out first, second but living room slide gets almost out it stops. We wait a few minutes then goes on out. No problems at all coming in. Someone told us the 'manifold' could be bad? Plenty of fluid in it. Any idea's what possibly could be? thanx.
18 REPLIES 18
bmcdonald
It doesn't seem to be a breaker or dirty slide.. the motor continues to run when the slide stops at a certain point. Maybe air in line?
1ofmany
newman fulltimer wrote:
your slide rails need cleaned and dry lubed .
Large slide is heavy dirty rails create resistance Auto reset trips cools comes back on slide goes out
Slide comes in less weight on rails less friction does not trip the reset fuse
Also dry lube and clean your slide seals
THIS IS PART OF MAINTANCE
Agree with newman fulltimer. I have been using a product designated to lube slide mechanisms followed by running a brush through the rail teeth...a somewhat tedious chore, but our slides move in and out smoothly and without the disconcerting screech we heard prior to taking this step.
Halmfamily
bobcouch wrote:
bobcouch wrote:
bmcdonald wrote:
bobcouch wrote:
One more vote for resettable breaker.
Unless you have a meter across the breaker when the slide stops, there is no way to know if the breaker is tripping or not. I just replaced mine to correct the same symptom.
If the breaker trips, would you not have to reset it each time if it is a breaker?
NO. We are talking about self-resetting breakers. It should look something like
It will be in line between the battery and the pump motor.
X3. Replaced my breaker a month ago. Same issue you are having. Ordered a new one and a spare off of Amazon for 8.00 each. Took five minutes to replace and issue solved.
2008 GMC Sierra 3500 SLT DRW D/A 4x4 (Big All)
2006 Ford F350 PSD SRW King Ranch 4x4 (Henry) (Sold)
B&W Companion, 90 Aux Fuel Tank, Scan Gauge II, Curt f/m hitch, Swagman XC
2015 Forest River Sierra 360 PDEK
DW Diane, DS Michael, FB Draco and Sabian
bmcdonald
Thank you very much, will go and check this out.
bobcouch
Bob and Honey Couch
2008 Keystone Everest
2007 Dodge MegaCab w/ 5.9 Cummins
http://boggythicket.blogspot.com/
bobcouch
Bob and Honey Couch
bmcdonald
bobcouch
Bob and Honey Couch
bmcdonald
No, plugged into 30amp under RV Port.
Pop-Pop_C
Could it be low battery?
bmcdonald
The rails are cleaned lubed on a regular basis. We cannot figure why sometimes it comes out completely, next time it may not. They are hydraulic slides.
newman_fulltime
bmcdonald
The big slide goes out, stops about 2ft.. have to wait a bit and then it will go out or slide back in, slide out again and it goes completely out.. Not breakers, they all are fine.
waltbennett
It's the auto breakers. They age and trip easier and easier over time. Getting a new one might cost you $5 - $10 at most. Make certain you disconnect all power and battery cables before replacing one.
'06 F350 TD, Softopper, airbags, AeroShield, coolant filter
'10 3665RE Hickory edition, wetbolts, Firestone LTs, Trimetric Battery Monitor, 4x100w panels & Morningstar TS-45, still tweeking.
