slideout topper
tj0855
Had one, now have two slideout toppers that stop zlide from rollong out unless I smack the safety travel lever and it will roll 1 revolution and hangup again.....any suggestions for ontheroad repair or temp fix till get home?
1 REPLY 1
garyemunson
Without a pix I'm not sure of your problem but often the 'safety bar' is mis-adjusted from installation and needs to be moved just a little. Mine are slotted and have 2 phillips screws that can be loosened so it can be slid back and forth.
