โAug-02-2017 04:47 PM
โMay-04-2018 04:19 PM
โMay-04-2018 05:15 AM
โMay-03-2018 12:26 PM
missourijan wrote:
I didn't see any other comment like this, this company is not Tiffen. While it was started by a son of Tiffen, there is no connection to the Tiffen company. Separate entity.
โMay-03-2018 10:27 AM
โMay-02-2018 04:15 PM
โMay-02-2018 10:00 AM
Robin1953 wrote:justme wrote:
CCC is a problem. If the frame is strong enough it could use 8K axles. I know disk brakes are a factory option, but not the axles. The Vilano seems nicely built with a great company behind it and I hope they do something about the CCC. In that case I might consider one because I would carry more than plastic diner ware and paper plate ๐
I am having the same issue with the CCC. I am looking into the possibility of replacing my Solitude with a Vilano 369FB. Since I am full timing CCC has to be a consideration. My Solitude has a CCC of 3534# whereas the 369FB has 1900# of CCC. The local dealer doesn't stock the 369 so I would have to order one. There are a few options that I would like since I am ordering one which would reduce the 1900# as well. I have subsequently found out that there is a non-published option to go with 8000# axles versus the standard 7000# axles that according to the company rep that I have been in contact with would raise the CCC to 3900#. This is a $3,633 option.
They are a well built unit with solid wood cabinetry, facias, etc. as well as solid surface counter tops and even the dining table is made from the same material. It is a great looking unit but the CCC is a major concern for me. It is a hefty price to pay in the first place but then have to add an additional $3,600+ to make it full time compatible for me since like you I carry more than plastic dinnerware is sorta of a bitter pill.
โMay-02-2018 06:52 AM
โMay-02-2018 06:46 AM
goducks10 wrote:Me Again wrote:
Come on, they build a 5th will that costs over a hundred grand and they can not put a rear cap on it? No way Jose'!
You get the rear cap if you get the Beacon version. Full body paint too.
https://www.rvtrader.com/listing/2018-Vanleigh-Rv-Beacon-The--39-FBB-5000460609
โMay-02-2018 06:42 AM
โMay-02-2018 05:24 AM
โMay-01-2018 07:17 PM
โMay-01-2018 06:25 PM
โAug-03-2017 03:51 PM
โAug-03-2017 12:23 PM
โAug-03-2017 10:31 AM
