Oct-29-2014 08:33 AM
Nov-02-2014 07:55 AM
Oct-31-2014 10:20 AM
Me Again wrote:SH wrote:
Thanks for the info BO...now the challenge is finding such a shop in my area!
Call Smiley's in Mount Vernon as a starting point. Either they can help you or will tell you who can.
18022 Washington 536, Mt Vernon, WA 98273
(360) 424-7338
Oct-31-2014 08:59 AM
(360) 424-7338
Oct-31-2014 07:06 AM
Oct-30-2014 09:46 PM
Oct-30-2014 04:39 PM
SH wrote:There are three aspects to aligning trailer axles. Tracking, which is how square the axles are to the frame. Toe, how much the wheels or wheel is point toward or away from the opposite wheel on the same axle. Camber, a measurement of how vertical the wheels are, tipped in at the top or tipped in at the bottom. A quality alignment will check and adjust all three of these measurements if needed.
So....I have not read many posts on the Correct Track alignment system. Does anyone have this and/or have any reports on how well it does or doesn't work?
Oct-30-2014 04:05 PM
Oct-30-2014 05:11 AM
Oct-29-2014 08:30 PM
Me Again wrote:
Maybe those two tires have ply separations on the outer ribs.
1. Quality Tires
2. Axle alignment check at a big rig truck shop.
Oct-29-2014 07:18 PM
Oct-29-2014 05:36 PM
Oct-29-2014 05:10 PM
Oct-29-2014 01:21 PM
rattleNsmoke wrote:
Next time I'm in Utah.....I'll look them up. Thank you.
Oct-29-2014 10:36 AM
rattleNsmoke wrote:
Finding an alignment shop might present a problem. I must have called 6 truck\trailer shops around southern CT and none would\could align a fixed, solid axle.
