Toilet Keeps Clogging: Macerating Toilet Effective Solution?
MtnMike
In our 2016 Jayco Pinnacle 36FBTS, the Front Toilet Keeps Clogging. We've used various methods to clear the clogs; plunger, plumber's snake, toilet wand, septic-safe chemicals. Once cleared, though, it will clog again within a few days, even with family members claiming that they flush with a lot of water, even flushing twice, when flushing septic-safe and rapidly dissolvable toilet paper. The clogs all appear to occur where the sewage line from the toilet makes a 90 degree turn (or perhaps more than one 90 degree elbow) about 8 feet down the line (based upon how much plumber's snake is worked down when trying to clear the clog). One neighboring rig owner told me his coach uses a macerator toilet and he's never experienced a clog in the year's that he's be living full-time in his rig. An in-line macerator, beneath the toilet, would reduce all flushed items to a slush to easily make the bends in the lines beneath the floor. Is there such a solution, or must I replace the existing Thetford porcelain toilet with one of their macerating models? Do they make a porcelain macerating toilet? Has this solution resolved this constant clogging issue in anyone's experience?
MtnMike
2016 Jayco Pinnacle 36FBTS Fifth Wheel
2017 Dodge Laramie Longhorn Ram 3500; 6.7L Cummins Turbo Diesel, DRW
20 REPLIES 20
westernrvparkow
To quote the great Howard Wolowitz: " It just wasn't designed for Russian cosmonauts and their potato-based diet."
dave17352
Interesting problem. I can see this happening with a 90 degree bend and such little water usage. Interesting they would design it that way. Seems like it is designed to fail. I hope I am wrong.JMHO
NOW 2017 Leprechaun 260ds
2005 Forrest River Cardinal 29rkle FW
1998 Lance 980 11'3" TC
2017 CHEVY 3500 SRW 6.0
B@W turnover ball @ companion Hitch
Honda eu3000 generator mounted on cargo rack
Crestliner 1850 Fish Ski boat mostly fishing now!
darsben1
Have you consulted Jayco about problem? If it is a design problem you are probably not the first complaint; I would also ask on the Jayco's owners forum.
Could there be an obstruction in the line? How far from the end of line does the clog occur?
Can you use something like this
LED 7MM For Android OS Automotive Inspection Camera Endoscopy Pipeline Endoscope
to inspect the bore to see if the piping is clear?
Traveling with my best friend, my wife in a 1990 Southwind
Old-Biscuit
"...... even with family members claiming ....."
stickdog
I bet if you google it you'll find out.
9-11 WE WILL NEVER FORGET!
FULLTIME SINCE 2010
17 DRV MS 36rssb3
17 F350 King Ranch CC DRW 4x4 6.7 4:10 B&W hitch
John
“A good traveler has no fixed plans, and is not intent on arriving.” Lao Tzu
newman_fulltime
to much tp is being used at once
