Towing grand design 303rls
sk734
Anyone towing one of these with 2014 Chevy 2500? This is my truck with towing package 4.10 rear end 6.0 gas motor and 3,115 Payload.I would like to know how well it would tow it. Thanks
5 REPLIES 5
RinconVTR
You've got plenty of payload and motor with the 4.10 rear end gear.
If you are not commercially towing every week or month, you've got it made.
Let that engine rev when it needs to and don't be shy with your right foot in fear of breaking something, such as high RPM will blow the motor. This is why gas motors get a bad rap...very very few actually use a gas engines available power!
Headed_West
DW and I pick up our new Cougar Half Ton 30 RLS on the 14th. We have a 2016 F-250 crew with the 6.2L. We are upgrading from a TT. I asked the very same question on this Forum. Everyone said I'd be fine.
2016 F-250 Crewcab 6.2L 4x4
2018 Keystone Cougar Half Ton 30RLI
jkwilson
I pull a 303 with an F250 6.2L. You wonโ€™t win any drag races, but youโ€™ll pass people on the interstate and be able to at least run with the semis.
John & Kathy
2014 Grand Design Reflection 303RLS
2014 F250 SBCC 6.2L 3.73
Lwiddis
Iโ€™ll look up all the weights etc. so I can respond. OR You could have posted those numbers.
SugarHillCTD
No responses yet so I'll throw my input here. Not the same unit but very similar tow vehicle. Look at my signature- gas engine like yours.
Recently went from carrying a very heavy truck camper to pulling a short 5th wheel.
Our new-to-us 5th is 7000# empty, so that would be a ton less than a GD 303. We are in the New Hampshire White Mountains and while the truck doesn't pull like a diesel, it doesn't struggle. It gets about 9 or so mpg in our "hills". The 6 speed trans is a big improvement over the older 4 speed.
On the flats to rolling terrain you should be good. Hopefully others will add their input. But the diesel folks might have different opinions.
John & Cathy
'12 Chevy 2500HD CC 4x4 sb
'16 Cougar 25RKS w/ Andersen rail mount
'13 Eagle Cap 850 (sold). B4 that a few other TCs and a TT
