โFeb-17-2021 09:19 AM
โFeb-18-2021 08:55 PM
โFeb-18-2021 08:24 AM
โFeb-18-2021 07:40 AM
4x4ord wrote:cummins2014 wrote:4x4ord wrote:
Your upgrades .... exhaust brake, turbo, additional power and transmission, plus the fact that you've got a dually should allow you to very easily handle a 13k 5ver. I would consider a 13k 5ver a light trailer. If you have a gear that will put your engine at an rpm where it makes 400 HP @ 55 mph you will be able to maintain that 55 mph up a 7% grade towing 13k lbs.
I agree ,but if you have dealt much towing fairly heavy with a 7.3 the ETG's are the limiting factor. I dealt with it nearly the whole time I owned that truck ,nearly 16 years . A stock 7.3 just doesn't have it for a heavier fifth wheel , unless you do some mods. I did a few ,and it did help, but the ETG's were the limiting factor, as said it had it there ,but the ETG's would climb up over 1200 degrees ,and I had to get out of the throttle.
Back when the 7.3 was very popular ,and new, ETG's were always a subject on the forums . Water injection, bigger intercoolers etc to deal with it.
I know very little about the 7.3 diesel and you're absolutely right that EGTs are often the limiting factor pulling grades. Even though the OP has upgraded his turbo, he may or may not be gaining a whole lot as far a EGTs are concerned, because he is also adding fuel .... he's going to need to be watching his pyrometer. I would think 1200* is a very safe level to run the EGT to, so ong as it is being measured pre turbo. I ran my Duramax to 1400 at times and as far as I know it never hurt anything.
โFeb-18-2021 07:18 AM
โFeb-18-2021 06:14 AM
Wadcutter wrote:cummins2014 wrote:
As said I towed nearly 16 years with the the early 99 Superduty 7.3 350 short bed. I wouldn't say I had a problem towing in the rockies considering I live here in the west. The most I towed was just over 13K , 38' fifth wheel. Have talked to many many people towing with a 7.3 over the years. Just curious occasionally I hear comments similar to yours , never had a problem, as said neither did I , but hopefully you were are a grade with a passing lane or you were holding up traffic ๐
Driving on grade with the 7.3 and 5er is no different than any other vehicle. You adapt to the vehicle and conditions. As you know there are a bunch of semis that creep up the grades. Too many drivers think because the speed limit is 70 mph that they need to keep going 70 mph up a 6+% grade. Then wonder why at the top of the pass their temp gauge is well into the red and others are sitting there with their hoods up and water on the ground.
Same with going down the grade. Just because the speed limit is 70 mph doesn't mean you have to run 70 mph downhill and ride the brakes. But we've all seen too many pulling trailers who do it. Not only seen them but smelled them when they went by.
It's not rocket science. It's knowing how to adapt to the conditions and vehicle. Doesn't matter if the vehicle has a 7.3 or a Detroit diesel or a 1.6L gas.
โFeb-18-2021 05:25 AM
โFeb-17-2021 04:26 PM
TXiceman wrote:
We had a 2002, 7.3L dually that we used to tow pretty much at rated limits. The truck had a SuperChips Micro Tuner and gauges for Pyro, boost and tranny temp. The tranny is a weak point in those trucks. I installed an upgraded torque converter, large stacked plate oil cooler and ran synthetic tranny oil. The truck did a great job, but I had to keep an eye on the pyro when pulling grades and back out of it at times.
Keep an eye on the tranny temp and pyro and roll on. The exhaust brake would be great.
Ken
โFeb-17-2021 04:24 PM
StirCrazy wrote:adamis wrote:
As my wife and I look at making the transition from a Truck Camper to a 5th wheel, the question about the suitability of our truck for the job comes into question. Someday a new truck with all the bells and whistles (and the quietness) might be on the table but not immediately.
My current truck is an early 1999 F350 Dually Quad Cab Long Bed 2WD. I've pulled my fully loaded 5k lb Truck Camper plus ~3k lb cargo trailer without any issues. I bought the truck off a guy who used it to haul his drag race car around in a 32ft goose neck trailer. I think he liked to work on the truck almost as much as the race car. Lots of "extras" all over the place. On a recent 3000 mile road trip I had a fuel injector go bad so I took the opportunity to dump about $8k into the engine, to include bigger injectors, bigger turbo, new up pipes, new HPOP and Hydra Tuner. The tranny has the 6.0 oil cooler mod and a Banks Torque Converter and Shift computer installed. Stock the truck made ~20lbs of boost, I'm now pushing 30lbs+ and haven't really tested the limits yet (nor do I plan to). My mechanic (who used to drag race 7.3s) guesstimated the HP to be in the realm of ~400 to 450hp. I am not going to dyno it but seat of the pants dyno I don't doubt it is far off from his guestimate.
Getting back to the towing part... I know the towing limit of my truck is right around the 13k lb range. I'm looking in trailers that are in the 12k to 13k range (and expect about another 1k lb in weight once packed. Pin weight for trailers in this range looks to be in the 2500lb range which is half of what my camper weighs when loaded so I think I'm not concerned about that.
My question really isn't about whether I will have the power to tow it (or the legality of it) but rather the handling / braking aspect. I already have a brake controller but might update it to something more modern. I'm thinking about specing the trailer with disc brakes to give more stopping power.
Does anyone else have experience towing heavy trailers with the 7.3 and if so, do you have an recommendations on what to do or not to do as far as mods and upgrades?
I had a early 99 7.3 that I had up around 450 hp and 935Ft-lbs. mine was a 3/4 tone, automatic, 2WD, shortbox super cab. when I bought my 5th wheel (39.5feet long and 14-16K lbs) I did a couple trips with it and it towed it just fine and got very good milage. The only reason I bought the 2014 was that with the 5th wheel on and no passengers I was already 300lbs over my max for the rear axel. If I would have had a 1 ton I would probaby still have it.
I never had any egt issues, just gear down out of overdrive and keep the reves up and slow down a little andit was fine. going up a grade 8-11 hill I was able to maintain 55 to 60 mph, and the pour man exhaust brake(EBP control valve control kid) was able to hold it pretty deicent going down a grade 6 hill.
I a seeing a lot of coments about drum brakes, My early 99 came with 4 wheel disk ABS all around , thought they all did...
having said that, even though I had the 7.3 hopped up so much my 2014 with 400/800 out towes it hands down in the low and midrange rpms and is a much more plesent truck due to the smoothness and quietness. The 6.7 is the first motor that I would consider better than the 7.3
Steve
โFeb-17-2021 04:12 PM
โFeb-17-2021 04:03 PM
โFeb-17-2021 03:48 PM
ford truck guy wrote:
I went from drum 12 x 2 to drum 12-1/4 x 3-3/8 to disc... I too will NEVER go back to drum brakes...
โFeb-17-2021 03:31 PM
โFeb-17-2021 03:27 PM
Wadcutter wrote:
I had a 99.5 F-350 SRW, crew cab, 4X4, 8 ft bed with the 7.3. I didn't have near the upgrades you've done. I ran a small programmer which gave me a little boost in HP and torque. I did the programmer mainly to get better shifting as it tweaked the shift points. I did not have an exhaust brake.
The last 5er I pulled was a 40 ft which loaded maxed at 14,500. Never had a problem pulling. Made numerous trips thru the Rockies. Pulled some pretty good hills and never had a problem. Even with SRW it was very stable in any wind direction. Without the exhaust brake I had watch downhill runs but that would have been the case with any truck. I never had the 6.0 cooler. All stock except for the low grade programmer.
The 7.3 was a good engine. A local truck mechanic friend kept trying to get me to really hot rod it saying it was near bullet proof and could really be turned up. It did all I needed without hot rodding it.
โFeb-17-2021 03:19 PM
adamis wrote:
Thanks, that is exactly the type of info I was looking for. Yes, I do have the Banks Exhaust brake already and use it all the time with the current setup. It has been a fantastic tool in the toolbox for handling the mountains.
EGTs since the Turbo Upgrade have been very good. Truck hardly breaks a sweat pulling the 9000lbs of Camper and Trailer now. I do believe the 5th wheel will test it more but like you, before the upgrades I've done the 35mph in second gear without much issue. Maybe I will be able to maintain 45 or 55mph with what I have now which would be just fine.
If the disc brakes are that much of a difference, I will make that a priority. Stopping that much inertia is really my largest concern for sure.
