Triple Axle Tire Rotation
slb5146
I am getting ready to replace 22 bushings on my 2014 Voltage Toy Hauler with Never Fail Bushings. I thought I would rotate the tires while they are off the RV. I can not seem to find a rotation diagram anywhere. Can someone please direct me to a link showing how to rotate the tires on triple axles?
Steve Brown
16 REPLIES 16
Oaklevel
Personally I never rotate trailer tires (30+ years) they will usually dry rot before they ever wear (unless something else is wrong with the axle)........... Should be replaced about every 5 years never had trailer tires tread wear out......but it won't hurt if you want to rotate them........
lincster
I rotate my tires once per year when I do bearings. I keep tires on the same side of the trailer, just move the front tire to rear axle, middle to the front and rear to the middle.
2022 F350 PSD CC 4X4 Dually to pull 2006 LE3905
Lincsters Truck/Trailer
Lincsters Rail
