TST tpms battery change?
7_3_psdman
Do you know if there is a video or other clear instructions for a step by step, how to change the batteries? I have the oring kit from TST now and am waiting on some batteries I ordered. It looks like it might take some fine tools to change the rubber disks but I haven't taken one apart yet to look at it. Thanks for any suggestions! Moderator, Please post this where it is appropriate. Thank you
4 REPLIES 4
edatlanta
That o-ring is very tiny and a bit hard to get on, but it does fit. I was scared I would break it, but it went on. I too have had to replace the sensor to valve stem gasket on a couple of mine, but TST sent me several spares of this gasket as well as the o-rings. Wal-Mart sells the batteries, but they are in the watch/jewelry area.
Ed
KM4STL
2006 GMC 2500HD CCSB 4x4 Duramax/Allison, Titan 52 gallon fuel tank, Prodigy Controller, B&W Companion Hitch, Progressive Industries EMS-PT50C, TST Systems 507 TPMS
2010 Jayco Designer 35RLTS,Cummins/Onan RV QG 5500 EVAP
Fulltime since 2010
Ed9824v
I. Did one of mine new o ring is a must and took a lot of force to push out the battery, went back easy though
Ed So.Calif
1950 Ford F1 street rod
1968 Baha Bug with 2.2 ecotec motor 170 hp, kingcoil
2000 National Sea Breeze 5th wheel trailer
1998.5 Dodge 2500 4x4 Cummins,4.10 gears,turbo,trans,injectors,oil cooler,lockers,edge EZ, 35" BFG's, air dog lift pump etc.
AniJet
Just replaced the batteries in six of mine. If you have the anti-theft caps installed you will need a very small phillips screw driver. Take out the three screws and remove the cap. Then use the install tool to hold the sensor and unscrew the cover with your fingers. The battery slides out. Install a new battery paying attention to the polarity and reassemble using a new Oring. I elected not to reinstall the anti-theft covers and just reinstalled on the valve stems. I have since requested and received some new sensor to stem seals. I need to replace a couple of them, maybe later this week.
07 Mobile Suites 36TK3 Demco GlideRide PIn Box
12 3500HD D/A CC 4X4 AirSafe Hitch
dbbls
I haven't done it but it looks like you would just remove the two screws and the plate would come off. Put the new o ring gasket in place and replace the plate. I guess you are referring to the new 507 from TST.
2011 F-350 CC Lariat 4X4 Dually Diesel
2012 Big Country 3450TS 5th Wheel
