Dec-12-2015 12:42 PM
Dec-14-2015 07:49 AM
Dec-14-2015 07:42 AM
Cummins12V98 wrote:Charlie D. wrote:Cummins12V98 wrote:b727capt wrote:
Do the better tires GY Michelin fail catastrophically like the Chinese brands?
NO
But some of the Michelin B.F.Goodrich Commercial T/A's do and BFG would not warranty mine. I understand that they have replaced them with a different construction.
GY is the only one that does and will pay for non road hazard damages that I know of.
Dec-14-2015 06:56 AM
RustyJC wrote:
If anyone is thinking of upgrading, here's another website that I used when I upgraded our previous Mobile Suites from 16" G-rated Goodyear G614 RSTs to 17.5" Michelin XTAs. I've been extremely satisfied with their prices and service:
Trailer Tires & Wheels.com
Rusty
Dec-14-2015 06:51 AM
Jimf1234 wrote:
The other issue is that I'm sure my wheels are only 80psi so it doesn't do much good to run g's at 80psi.
Dec-14-2015 06:48 AM
NO
Dec-14-2015 06:30 AM
Dec-14-2015 03:10 AM
Dec-14-2015 02:55 AM
But do you need 4800# capacity per tire at `125# ?
That's 19,200# of capacity.....
6K axles-------Approx. 11,500# or less weight on axles
I agree 17.5 wheels appear to be over kill.
I have 16", G rated,110 PSI Sailun's on my OEM rims
The problem is you are overloading those tires at 80psi
Dec-13-2015 04:25 PM
NO
Dec-13-2015 12:05 PM
Dec-12-2015 09:34 PM
Dec-12-2015 08:01 PM
b727capt wrote:Zero problems with my Michelin XPS Ribs in 4years and about 30,000 miles.
Dec-12-2015 05:36 PM
Dec-12-2015 05:05 PM
Dec-12-2015 04:31 PM
85psi is the minimum for the GY "G" tire. If your rig came with E's 85 is most likely the proper pressure for your rig. I went from GY "E" to GY "G" on my Avion with 80psi rims and ran 85psi with the G tires and had perfect wear with thousands of miles.
What is your tire rated at? At what psi? a g tire rated at 4085lbs at 110psi is only good for 3152lbs at 85psi
