Jul-10-2017 10:54 AM
Jul-15-2017 04:54 AM
Jul-10-2017 01:50 PM
Allworth wrote:
You might try measuring from the input wire of the switch to a chassis ground. You should get battery voltage.
Then (with the pin in place) measure output wire of the switch to ground and it should be zero.
Pull the pin and output wire to ground should be same as battery voltage. i.e. there should be NO internal loss in the switch. If there is, the switch is defective.
A
Jul-10-2017 11:00 AM
