โNov-03-2014 06:03 AM
โNov-05-2014 07:51 AM
jamway wrote:Mile High wrote:TXiceman wrote:jamway wrote:TXiceman wrote:
AS pointed out....water is heavy and is 8.33 #/gallon. Can the tow vehicle carry the added weight. Next, will your waste tanks store the extra volume. You can't dump it on the ground.
Ken
We use 7 gallon blue jugs and use a 12 volt pump to put water in the trailer.
We have camped in many campgrounds where you could run the gray water into an area where the trees are.
We find most if not all Texas state parks specifically list dumping of gray water on the ground as illegal. Too many food particles and the smell attracts the little critters.
Where have you been dumping the gray water and we will not bother to go there.
Ken
Keep it in Texas!
I don't know of a campground in Texas that dumping gray water on the ground is legal but in NM and CO there are many. (Mile High note CO.)๐
Many Forest Service campgrounds in CO. and NM. it is legal to dump gray water. Very few times will it wet an area as large as your spare tire.
We will miss getting to see you Ken but that will give us one more spot to choose from.
โNov-05-2014 07:44 AM
Ken
Ken
Keep it in Texas!
โNov-04-2014 06:48 PM
Ken
Ken
Keep it in Texas!
โNov-04-2014 05:12 PM
lee worsdell wrote:
My current trailer only carries 45 gallons of fresh water plus hwt. Are their any other ways to carry extra water, have people made their own . Just wondering would like to double my water with out buying new fver
โNov-04-2014 08:23 AM
bpounds wrote:Mootpoint wrote:
I have 2 - 45 gallon water bladders from Camping World. I use one for freshwater and one for waste water.
The fresh one is self explanatory. I fill the waste one with a portable macerator and using a system I rigged up of fittings I pump it out with the same macerator.
I have used this system many times in remote parks and while boondocking in Quartzsite.
Try not to mix those up, K? ๐
โNov-04-2014 06:50 AM
โNov-04-2014 06:19 AM
โNov-03-2014 08:31 PM
โNov-03-2014 06:52 PM
Ken
Ken
โNov-03-2014 06:23 PM
Ken
Ken
โNov-03-2014 06:14 PM
Ken
โNov-03-2014 05:47 PM
Ken
โNov-03-2014 05:05 PM
TXiceman wrote:Many National Parks allow grey water to be released on the ground. We don't put lotsa nasty stuff in our grey tank, so I periodically do bleed a little off when necessary and LEGAL!
Ken
โNov-03-2014 04:59 PM
lee worsdell wrote:I use this bladder and it works great. I bought an inexpensive 12 volt transfer pump from Harbor Freight and use it to fill onboard tank. The bladder folds up to about the size of a set of sheets and stows nicely. It even comes with fittings and a repair kit. You might also purchase a "water thief" fitting ($5:00) from camping world. this allows you to hook on to smooth unthreadded hose bibs to fill the bladder.
thanks hondavalk I should of explained my self little better. dry docking is when I need it going to a few big events this year and they don't have water trucks or hook ups. seems I always run out even if we conserve shutting off showing then on when lathered up. I just found a 45 gallon bag that camping world sells
