Water Heater Relief Device
Esacnj
Is it normal for pressure relief valve/device to release small amount of water periodically?
Esacnj
18 REPLIES 18
Lynnmor
The water heater will lose the air pocket over time, when that happens the pressure can go up and cause a release of water. You need to re-establish the the air pocket by draining the tank and refilling. If that doesn't cure the problem. replace the T&P valve.
bobsallyh
No, it isn't normal but if the water heater is heating the water too hot it will open to release pressure.
Flute_Man
No. You need to replace it. Simple and easy.
Jerry Parr
05 Mandalay 40B
Cat C7 350
04 Honda CR-V
Ham Radio K7OU
Retired EE
Jrparr32@gmail.com
602-321-8141
Full-timer
Lwiddis
NO! This indicates water pressure is too high and/or failure of the regulator.
