Water pump
roachcoach
My fresh water tank was filling up when on city water hookup so installed new water pump but its still doing the same thing. I have a 2013 Heartland Landmark fifth wheel.
Richard & Rachel
2006 Damon Astoria Diesel Pusher
2004 Jeep Liberty
3 REPLIES 3
eHoefler
ANderson valve is bypassing
2021 Ram Limited, 3500, Crew Cab, 1075FTPD of Torque!, Max Tow, Long bed, 4 x 4, Dually,
2006 40' Landmark Mt. Rushmore
enblethen
Check your fill valve position if equipped.
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
Itchey_Feet
I solved our problem by replacing the divert-er valve. The one you choose for city water or fill the onboard tank. Also found that the original valve was put in backwards.
My feet are fine as long as they are traveling.
