โJun-15-2020 07:36 AM
โJun-30-2020 07:33 AM
phillyg wrote:
Already got the FW back after they told me $2,300 to replace all four backing plates, etc.
โJun-30-2020 07:31 AM
โJun-29-2020 01:58 PM
โJun-29-2020 01:45 PM
phillyg wrote:
Now boys (and maybe girls), my original post was only to determine if the price quoted for repacking was fair. It doesn't need to devolve into disagreements about the quality of bearings, lack of quality control, or technical expertise, etc.
โJun-29-2020 01:31 PM
โJun-29-2020 01:09 PM
Lynnmor wrote:
The remaining ridge is still quite visible and I am showing the remaining height. I have been in the tool & die business for more than half a century and understand how things are made. If you cannot or will not accept what I have presented, fine. I still have a customer that his entire business is bearing failure, preventive maintenance and lubrication analysis, he is in total agreement with my conclusion. Perhaps you have more expertise than the both of us.
โJun-29-2020 12:59 PM
โJun-29-2020 10:29 AM
Lynnmor wrote:As I said, you could be correct, based on the available evidence. But I've worked around bearings and machined surfaces also for 40 years, and I've seen bearings fail and look just like that. Since I had put the bearings together, I knew they were good from the box. I don't know that I have more expertise, but I know that after the fact analysis doesn't always result in the correct answer. Just the way things go.
โJun-29-2020 09:47 AM
fj12ryder wrote:
Ah, so you pulled the bearing apart before you ever traveled and found that the inner race was bad. That would be the only way you could determine that the race was bad from the factory. Yes, it could have been caused by what you described, or it could have been caused by something else. Unless you saw it new and unused, it's just speculation.
โJun-29-2020 09:09 AM
โJun-29-2020 08:50 AM
โJun-29-2020 08:00 AM
โJun-29-2020 07:50 AM
Lynnmor wrote:
Here is one of my faulty Chinese bearings in one season, and I don't drive like a jerk:
โJun-29-2020 07:47 AM
