Window blind integrated to door install help
tourusa
Hi I have a lippert door and am unsure if it’s compatible with the integrated blind system
Any way to tell if my door is compatible
Currently coast to coast
F350 dually 2020
2020 Vanleigh Pinecrest 392MBP
B&W Companion OEM 5th Wheel Hitch for Ford Super Duty Prep Package - Dual Jaw - 25,000 lbs
ITEM # BWRVK3305
6 REPLIES 6
StirCrazy
Moderator
Moderator
tourusa wrote:
yes it is but there are two different sizes a shorter one and a longer one so you have to measure and get the right one. I just did it on my camper, best thing I ever did but I do tend to leave it closed most of the time as I have a screen door so you have to open the doors to change it.
Steve
2014 F350 6.7 Platinum
2016 Cougar 330RBK
1991 Slumberqueen WS100
tourusa
Ok thanks much found some you tube videos appears to be straight forward
F350 dually 2020
ITEM # BWRVK3305
fj12ryder
I believe it can be determined by the window size.
Howard and Peggy
"Don't Panic"
tourusa
F350 dually 2020
ITEM # BWRVK3305
tourusa
F350 dually 2020
ITEM # BWRVK3305
tourusa
F350 dually 2020
ITEM # BWRVK3305
