I have a small enclosed utility trailer I use for camping that I can run off of vehicle wiring or I can plug the 7way plug into a receptacle I have wired to a separate battery. While cutting wires, to hook up a 12v cigarette lighter type receptacle, I made the mistake of grounding out the wires before I hooked them up. I had the radio going inside the unit as well as an interior light. When the cut was made, both units quit working. Now when I hook up a test wire to the negative side of the battery and touch the tester to a ground inside the unit, the test light comes on, indicating I have positive going to the frame of the trailer. To top it off, when I now plug the trailer into my vehicle, the right tail light comes on on my truck. HELP - any advice or assistance would be most appreciated. Thank you.
