skinden
May 17, 2018Explorer
01 Holiday Endeavor Diesel ignition problem
I have a problem. When I turn the key nothing happens on the dash where all the gauges are. House batteries and the Cranking batteries are fully charged and the switches are in the on position. The alternate switch that helps crank with use of the house batteries does not function. I recently removed a motion sensor that was hardwired into the 12 V system. I guess what I’m looking for is a reset switch or the location of the ignition fuse ....
