07 fleetwood revolution le 40v light issues
19bigred59
I'm taking a shot hope someone can help I've lost all marker and running lights I have headlights and dash lights turn signals and brake lights all work I've checked and rechecked all the fuses and relays multiple times
Thx
6 REPLIES 6
Executive45
Fuses should be checked with a meter. I would not suspect a fuse however. My bet is on a bad ground from one of the lights....Dennis
cavie
Thx
How did you check the fuses? Where did you check the fuses?
2011 Keystone Sprinter 323BHS. Retired Master Electrician. Retired Building Inspector.
All Motor Homes are RV's. All RV's are not Motor Homes.
19bigred59
I'll try both those ideas
MountainAir05
Or a ground wire that starts at the first light or last depends on how they wired them.
Lwiddis
Have you checked the ground?
thelazyl
I'm not an expert but I did have a similar problem. It turned out one of the lights on the front roof had a water leak.
