12v power problems
Big_Jimmy
2011 tiffin open road 32ca - while camping and living room slide out was out and when trying to retract slide out it had NO power? Once we turned off the 12v system and then turned back on side came in as normal. Anyone know what would cause this? thanks
11 REPLIES 11
Big_Jimmy
thanks for the great information
CA_Traveler
Call Tiffin and find out about the reset.
Again - measure the amps to determine if you have excessive draw. And measuring voltage at the motor at the same time will also be helpful.
2014 Grand Cherokee Overland
Bob
lryrob9301
The problem is your HWH hydraulic pump master solenoid is starting to go bad. Here is a replacement HWH Master Solenoid.
This solenoid mounts directly on the pump motor. While your at it get 2 and replace both solenoids on the motor at the same time to prevent other problems later.
Big_Jimmy
Yes, moves great once the couch 12v power switch is toggled off then on again - that is what I don't understand?
MountainAir05
Is it moving now.
Big_Jimmy
This is the hydraulic slide.
lryrob9301
Is this slide hydraulic or electric operated?
Big_Jimmy
Engine is running when retracting slide-out
MountainAir05
What is your battery voltage taken off the battery with a volt meter.
CA_Traveler
Automatic CBs do just that. Most overheat with excessive amps and take time to cool off and reset. Measure the amps traveling in both directions and if excessive you might have a CB or slide issue or loose wire, low battery, etc. Resolve ASAP.
Bob
DrewE
Maybe a circuit breaker (or similar overload protection circuit); there are some that self-reset by having their power cycled.
