May-18-2014 07:22 PM
Mar-15-2021 01:48 AM
May-19-2014 07:44 AM
May-19-2014 06:48 AM
Handbasket wrote:
You _might_ find a repair manual on eBay or craigslist. Look for a Chilton's manual. The van & cutaway chassis are probably similar enough to be covered in the same manual. That will cover the Dodge wiring, but not the RV wiring.
If you haven't, also look in the muli-hundred page thread running here for older Dodge owners.
Jim, "Mo' coffee!"
May-19-2014 06:10 AM
May-19-2014 05:48 AM
toedtoes wrote:
I have a 75 Dodge B300. The power steering fluid access is in the center and low down in the engine (behind and below the radiator).
Have you tried changing out the battery? It may be that your battery won't hold a charge.
Not sure on the cutting out when put in gear. Mine runs great once I get it started... Have you tried giving it a touch of gas as you change gears (other foot on the brake of course)?
May-19-2014 05:29 AM
May-18-2014 07:41 PM
May-18-2014 07:29 PM
