1993 Newmar DP. What weight of fluid??
GMCK154X4
What type of fluid do I need to use in my hydraulic system reservoir?
I just replaced the lines and the filter and it looked like it had ATF in it. I've read that it should use 10w-40 oil and also read ISO-32 hydraulic fluid. It's a 1993 Newmar Kountry Star with an 8.3 Cummins on a Spartan chassis.
9 REPLIES 9
hipower
My '03 Dutch Star uses the ISO-32 hydraulic fluid. It isn't what I would call a widely stocked fluid, but any hydraulic parts dealer usually has it. Difficult to find in anything smaller than five gallon containers and even harder to get in my reservoir since the clearance is extremely tight for the filler. I use a cheap Harbor Freight hand pump to accomplish the refill.
There is a decal on the reservoir on mine that specifies the fluid type.
Ava
My 94 diesel Bounder calls for automatic transmission fluid in the Power Gear hydraulic system.
wolfe10
And, even on the hydraulic system (side radiator fans and/or power steering) there is no "here is what all of them use.
We have had coaches that called for ATF and one that called for Delo 400 15-40. Not a matter of better/worse, but what the system was designed to use.
Brett Wolfe
Ex: 2003 Alpine 38'FDDS
Ex: 1997 Safari 35'
Ex: 1993 Foretravel U240
dougrainer
wolfe10 wrote:
Indeed, contact Newmar for information on your jacks (not a chassis manufacturer installed component), OR contact the jack manufacturer.
There is no "here is what they all use"!
The OP was talking about the CHASSIS engine system fluid. The "tell" was, he stated he changed the filter/s. There are NO filters on a HWH or any Jack system. Doug
FormerBoater
I was apparently mistaken, but by referring to a filter and resevoir I thought the OP was referring to the fluid that runs his fan and his power steering, not the jacks.
Sorry about that!
Dave
1998 American Eagle 40EVS
wolfe10
Brett Wolfe
Ex: 1997 Safari 35'
JoeH
Call Newmar-- have your VIN handy and they should be able to help.
Or- go to Newmar support site --- go to the section that says coach specific, put in the ID info and go look at everything about your coach
Joe
2013 Dutch Star 4338- all electric
Toad is 2015 F-150 with bikes,kayaks and Harley aboard
FormerBoater
Definitely call Spartan.
Some used Dex III, others hydraulic fluid etc.
Only Spartan can give you the correct answer!!!!
Dave
jtessnm
Dexron II or III. I get mine from Chevron "MD-3"
Do not confuse me with facts, my mind is made up.
There is a difference between stupidity and ignorance: ignorance can be cured.
