โDec-13-2016 09:22 PM
โDec-14-2016 04:28 PM
happycamper002 wrote:
Big nonsense, CW replaced the blown airbag and corrected the problem.
How do you explain that.I still have the blown air bag to prove my point.
Try to make more sense in what you say to make yourself believable.
An Rv tech doesn't make an engineer.
โDec-14-2016 03:48 PM
โDec-14-2016 11:22 AM
happycamper002 wrote:darsben1 wrote:
This is the correct answer.
This is misinformation that shouldn't have been. You obviously haven't experienced a blown air bag on one side. I have the same size MH that OP has and I blew the passenger-side rear bag while driving from a lakeside CG in CA.
I couldn't stop on a single lane steep mountain road to check, and besides, there wasn't much I could have done anyway so I kept driving until I got to the nearest town. I pulled into a gas station and the best advice I got from the mechanic was I needed new shocks. (duh)
All that time I was driving from the mountain road, I got some well-meaning motorists behind me motioning that I'm leaning over to tip the MH due to bad off-level condition.
I have also witnessed school buses with blown air bags with the chassis almost touching the pavement.
I deflated the opposite side air bag to almost even out the off-level side to make it home that was almost 100 miles away.
My motor home and I assume most of them are, has almost all the weight on the passenger side: water heater, range, fridge, kitchen cupboard, 32 in flat TV, hood, propane tank and even the motorized doorstep. And to make things worse, the road crown is always sloping to the passenger side making liquid in tanks like fuel, waste and fresh water to settle or nest to that side too.
Weighing an empty RV doesn't reflect the real world condition.
I always check the level and pressure to achieve the level that I'm comfortable with. It doesn't have to be perfect but at least motorists behind you would not be concerned about you falling over the cliff when driving the shoreline of the Pacific Ocean in Northern CA.
Yes, to a certain extent, it does help in keeping the MH level.
โDec-14-2016 10:22 AM
โDec-14-2016 09:24 AM
โDec-14-2016 09:09 AM
Bud
USAF Retired
Pace Arrow
โDec-14-2016 08:27 AM
โDec-14-2016 08:17 AM
dougrainer wrote:
P30 air bags in the FRONT coil springs are NOT to level the motorhome. They are required and designed to INCREASE the front suspension load carrying capacity. Nothing else. AND you use the Chevy recommended pressures. Doug
โDec-14-2016 07:17 AM
DougE wrote:
I think one thing the air pressure pundits overlook is a primary function of the airbags to level the RV. Chevy had no idea how much load the RV manufacturers would be putting on the front end so the airbags give the ability to level the unit. So find a level slab, put a level on the RV floor and adjust the airbags accordingly. You may even find that getting the top of the wheel well even on both sides may require different pressures in each side.
โDec-14-2016 06:43 AM
โDec-14-2016 06:40 AM
Bud
USAF Retired
Pace Arrow
โDec-14-2016 06:33 AM
โDec-14-2016 06:20 AM
harold1946 wrote:
I suggest 70 psi. as a good starting point. Then adjust from there, up or down until you find the sweet spot, where the ride and handling suit you best.
I do not recommend going below 50psi.
โDec-14-2016 02:16 AM
