Chris,
Thank you for your response. Due to unknown history I traced all of the AWG2 cables and labeled each, then drew a diagram which includes the inverter/charger, the 150A fuse, the paralleling relay, and both battery banks. In case of uncertainty, I disconnected both ends of a cable and pulled it free to make sure there was not a hidden connection. Caution is definitely required due to the possibility of big arcs and blown equipment.
Thanks, John
