2004 Tioga 23e
hermanoW
I have no current to the tv outlet. There is a fuse marked TV and it has 12 volts passing through it. I cannot find the inverter that would convert that to 110. Thanks for any help you can give.
3 REPLIES 3
EMD360
Yeah, the GFI's are tricky little devils. Ours stops our kitchen outlet and makes us think the coffee maker is broken!
We also have a 12V receptacle in our TV cabinet and the outlet there can be turned off by a switch near the antenna booster and night light. More than once we have strung an extension cord instead of remembering that little switch.
2018 Minnie Winnie 25b New to us 3/2021
Former Rental Owners Club #137
2003 Itasca Spirit 22e 2009-2021
hermanoW
DUH!!! After scratching my head for two days, I finally found the ground fault reset in the bathroom! Problem solved...
dicknellen
Do you have 110v to your outlet when the generator is running or when you are plugged into city electric? A lot of that size NHs don't have inverters standard. Dick
