2005 Southwind Generator runs just fine but no power
cbelize
Left for dry camping on Friday evening. Pre checks included running the generator and verifying all AC outlets worked. I even ran the AC for abut 5 mins. Low and behold once at the camp site needed to run the microwave for a couple mins, turned the generator on started up no issue. I looked at the main panel on the wall next to the bathroom, I see nothing happening on the panel. Normally a green LED light would move around in a clockwise motion and then I would hear a clicking at the main circuit breaker panel as it checks all the breakers, once that is done I would see the LED on the panel lit up next to 30 AM or 50. Well the generator started up but nothing was lit up on the panel.. it was dark, and no power no none of the AC outlets. So I started at the generator, ONAN 5500, reset the two 30 AMP breaker,, no change, I reset the breakers at the main circuit breaker panel in the bedroom, no change, I pulled and verified all 3 fuse at the inverter under the fridge, no change...I reset the GFI AC outlet in the bath room. no change.. so at this point I am out of options. Now back home, I hook up to shore power all works.. Any help on this would be greatly appreciated. In addition to that the panel that show water levels, LP, Battery AUX and MAIN reading is completely dead.. no reading when the buttons are pushed... I appreciate your help.
17 REPLIES 17
crasster
Do you have any outlets directly on the generator itself or a way to test if you have power output @ the generator without going through coach wiring?
4 whopping cylinders on Toyota RV's. Talk about great getting good MPG. Also I have a very light foot on the pedal. I followed some MPG advice on Livingpress.com and I now get 22 MPG! Not bad for a home on wheels.
DrewE
Common causes include:
1. Output breaker(s) on the generator tripped. Some breakers don't look different when tripped, so flipping off and back on is a good plan.
2. If you do not have an ATS, you forgot to plug the shore power cord into the generator output socket.
3. Something is broken: ATS, wiring connections to generator, EMS, generator itself, ....
jerseyjim
Transfer switch ?
