2007 Winne Journey 39Z pasenger window - Moves on its own
mjaye655
Guys,
n a test drive I could move the right side mirror and position it but when driving it would drift again. I have read somewhere that is has to with a rod that has come loose in the mirror. Anyone have this experience? It does not occur quickly but over time.
Thanks
4 REPLIES 4
craig7h
Nomad II
Nomad II
On my 07 Meridian (sister to journey) the mirror does somewhat the same thing. If it is the whole mirror part that moves there are screws that can be tightened. By removing the protection caps the set screws can be seen.
If its the wind that moves just the mirror, mine does that also. I have tryed to move the whole mirror assembly so the wind may not catch the mirror. That seemes to help somewhat. I have no idea of the rod you are talking about.
Good Luck
Itasca Meridian SE 36g
Road Master Tow Dolly
mjaye655
I have not found a double post?
MountainAir05
Check the locking set screw.
MountainAir05
double post.
