2013 Meridian Wind Noise--Driver mirror
Mizzouri
I have a terrible wind noise with the driver side mirror. The mirror is offset from the front of the unit while the mirror on the passenger side extends beyound the from of the coach.
Winnebago says there is nothing that can be done it is a flaw in the desgin and could be corrected on future models.
Any suggestions for cutting the noise? If I slide open my window the noise is reduced as the wind is buffeting against the glass.
Help
2013 Itasca Meridian 38'
2014 Honda CRV
6 REPLIES 6
We_Cant_Wait
Others have solved this issue by ensuring that the mirror is adjusted in as close to the side of the coach's side window as possible, this puts the mirror in the coaches wind slip stream and air flows evenly over the mirror. This is what I've done with ours and it seemed to work out OK.
Mr_Mark1
Mizzouri, if I understand what you are describing with your mirror, the right mirror is sticking out on an arm, the driver's mirror is view from the driver's side window (not through the windshield).
Prevost had a vibration problem, not so much of a wind noise problem. But, the vibration was caused by the wind. To cure it, the driver's mirror was set close to the driver's side window, maybe about an inch or so away from the glass. It helped tremendously.
Good luck,
MM.
Mr.Mark
2021.5 Pleasure Way Plateau FL Class-B on the Sprinter Chassis
2018 Mini Cooper Hardtop Coupe, 2 dr., 6-speed manual
(SOLD) 2015 Prevost Liberty Coach, 45 ft, 500 hp Volvo
(SOLD) 2008 Monaco Dynasty, 42 ft, 425 hp Cummins
rr2254545
Help
Who at Winnebago told you this ?
2012 Winnebago Journey 36M Cummins 360
2014 Jeep Cherokee
492 Campgrounds,107K miles driven in our Winnebago motor homes and 2360 nights camping since we retired in July 2009, 41 National Parks
JNW57
Had a similar noise that I thought was the side mirror. Read a discussion on this forum about window weep hole covers as the cause. Didn't have any on the left side because FW installed right side covers on the left side & they all fell off. Purchased left side covers on EBAY & installed them on the driver's side window. Didn't hear the wind noise on my last trip.
2003 DISCOVERY 39L QUAD SLIDE
2014 HONDA CRV EX-L FWD
BLUE OX ALADDIN, M&G AIR BRAKE, KAR GUARD
krivanj
Make sure the inserts are all in the mirror. The previous owner on my coach told me he had a terrible wind noise that took forever to solve. Turned out one of his allen screw covers was missing. Cured the noise.
Fleetwood Revolution LE 38X
2011 Scion TC toad
rgatijnet1
I would ask Winnebago what the design change is and see if it can be applied to your coach.
My only suggestion is to tape various shaped objects to the back of the mirror to disrupt the airflow in hopes that it will minimize the wind noise.
