2014 Thor Vegas keyless hood latch ?
jolooote
My new Thor Vegas 24.1 has 2 hood latches that require use of a unneeded key. Anyone know what & where I can get to replace em with a keyless latch? Thanks
Joe & Charlotte
2020 Jayco Greyhawk Prestige 29MV Celestial Blue Full Body Paint E-450 305hp V10 6spd Class C 'COACH'
2012 Jeep Wrangler 285hp V6 'TOAD'
Gabby & Molly are Dogs
Leroy's a Conure, Loretta's a Squeaker
"Once it starts breakin'...GET RID OF IT!!!"
8 REPLIES 8
jolooote
I wonder if its even POSSIBLE to remove the battery! LOL
Joe & Charlotte
davidgebo
If a crook can get the battery out from under the hood in a Vegas, hire him as your mechanic. I can barely see the battery, never mind do maintenance on it
cwit
I had to use a key on my older fleetwood and found keyless latches at my dealer for under 4 dollars.
jolooote
No problem. Thanks
Joe & Charlotte
Effy
jolooote wrote:
Effy, THANKS for that great piece of 'help'. What is a "small inconvenience" to you is a Pain in the A.. to me. Thanks anyway for u'r 'help'...
Sorry, playing devil's advocate. You might end up paying for a lock-free latch and come up short a battery for your efforts. As often as I open the hood on my RV, using another key on the ring doesn't seem much of a PITA. But maybe that's just me. To each his own.
Didn't mean to offend. Good luck.
2013 ACE 29.2
jolooote
Joe & Charlotte
Effy
I'm confused. If the hood latches are keyed, and you have a key, why is the key not needed? Basically is it that you don't want to bother with a keyed engine compartment? Seems like a small inconvenience over security as much as you get under the hood.
2013 ACE 29.2
LVJ58
Have you tried checking with the manufacturer of your Thor Vegas?? If not, I would start there..
Good luck & safe travels...
Jim & Sherry Seward
Las Vegas, NV
2000 Residency 3790 V-10 w/tags & Banks System
2003 Suzuki XL/7 toad
