โSep-08-2014 01:42 PM
โSep-11-2014 07:01 AM
โSep-10-2014 07:05 PM
GlennLever wrote:wa8yxm wrote:
I measure voltage at several points..
I have a Surge Guard (A true surge guard with an LCD display) That monitors the voltage at the park end of the power cord.. Some day I'll move it inside but for now that's where it is.
Inside I have 3 meters, one is one of those square analong plug in ones I have had longer than I've had this class A, it is plugged into an outlet connected to ONE leg of my 50 amp service.
In another outlet, on the other leg, is a MFJ line voltage monitor, a very nice Analog meter with pass through and a backlight,, Both have "Expanded Range" meaning the "Zero" position ins really like 90 volts. (Makes them easier to read)
Plugged into the GFCI and thus inverter powered outlet is a Kill-a-watt NOTE Inverter is a pure or true sine wave (your choice of term) so the KAW does not object. I'm told MSW's can damage them but have never tested that theory.
IF there is a difference between the meter at the pedestal and the one in the motor home.. I have a problem
So what are they reading?
Have you talked with camp ground?
โSep-09-2014 01:16 PM
โSep-09-2014 12:43 PM
โSep-09-2014 05:52 AM
โSep-09-2014 04:59 AM
zman-az wrote:
I too thought inverter was running everything with low batteries but the OP said it was not on.
As suggested, what is the voltage at the pedestal when you run the microwave. If it drops then the problem is not the RV. I would check all electrical connections on the 50 amp circuit. A loose screw can cause these issues. Check the circuit breaker on the house/pedestal. Turn it off then put in a large flat blade screwdriver and turn the screw on the CB, if its loose snug it down. Also check connections on the transfer switch as well as the circuit panel in the RV. If any of the connections are loose it can create this issue. Make sure power is off and you have a insulated screwdriver so you don't electrocute yourself.
โSep-08-2014 11:28 PM
โSep-08-2014 08:41 PM
hooligan wrote:
If you have a voltmeter, unplug your 50 amp cord and measure the voltage at the socket on the pedestal.
โSep-08-2014 07:18 PM
โSep-08-2014 06:32 PM
โSep-08-2014 06:24 PM
โSep-08-2014 05:30 PM
JimM68 wrote:
If I was to take a really wild guess, you are no longer recieving shore power. The items you mention are running off the inverter, and your batteries are nearly discharged.
Off the wall? yes. Wild guess? sure.
Please, let us know: year make and model of your motorhome. manufaturer and model of your inverter/converter. Easiest to just pur your moho info in your sig....
โSep-08-2014 04:11 PM
โSep-08-2014 03:59 PM
