78 Blue Bird Breaker Box
judylaverty
Hi: We're new to the forum and happy to be here. We picked up our "new"
78 Blue Bird Wanderlodge and drove it home from Lovelock, NV to Truckee, CA. When we picked up the coach everything worked. After parking it at home, we can't get the generater started, none of the lights including the interior, turn signal, flasher, etc., dont work. All batteries are charged and the genny tank is full. We have searched to no avail to find the 12 volt breaker box or been able to figure out what is wrong. We did find a wire dangling down under the bus and it may be a ground wire. The owners manuals are useless as they refer to the breaker box but don't say where it's located. Also, the air step doesn't work either. We are beyond frustrated and completely puzzled. The coach starts up immediately, and the only thing that works is the sound system and the headlights. Can anyone out there give us some ideas as to where to start. Thanks, Bill and Judy
6 REPLIES 6
judylaverty
Thank you, everyone for your help. We will take your advice and search everywhere you suggested. Yes, we're on the Blue Bird forum also. I just know the fix is something simple that we are overlooking. We will keep you posted. Thanks again
erniee
look in the compartment under the booth by the door. there is a large transfer switch there. breaker box should be in a rear closet
Ernie Ekberg, Prevost Liberty XL Classic
MrWizard
Moderator
Moderator
sounds like you turned On a battery disconnecct switch someplace
not an uncommon thing
playing with switches, wondering what does it turn on or off
battery disconnect ON..means NO power in coach
you want battery disconnect OFF
it could be a rocker switch, it could be a Heavy knob type switch, old fashion looking
its common on the seller "walk thru" for the buyer to be so excited, he doesn't remember what the seller was pointing out
wander lodge was always top of the line
you got enough switches and gauges to rival a 747
I can explain it to you.
1997 F53 Bounder 36s
mike_brez
I would start Here
1998 36 foot Country Coach Magna #5499 Single slide
Gillig chassis with a series 40
02 Ford F250 7.3 with a few mods
2015 Wrangler JKU
1492
Moderator
Moderator
Moved from Forum Technical Support
gbopp
Welcome to the forum
I'm not familiar with your rig. On our 96 Southwind the breakers are located under the refrigerator.
Start looking and following wires.
Hopefully someone will post with the location.
Did you reattach the ground wire?
Also, did you search the web for a Blue Bird Owners forum?
Enjoy your travels.
